  New Posts New Posts RSS Feed - Odd Mounting Hole
Odd Mounting Hole
Message Reverse Sort Order
Naveed Khan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Naveed Khan Quote  Post ReplyReply Direct Link To This Post Topic: Odd Mounting Hole
    Posted: 13 Mar 2013 at 2:17am
FP for same I have created pad over pad.
Mfr. Part No : 1-1469491-3
budnoel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote budnoel Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2012 at 9:04am
Note 4 indicates that there is a pad on top and bottom of pcb but it doesn't give the size.  Note 3 indicates what the angle of rotation for location of the second hole.   I created a 10.02 pad with a 5.15 hole for the first padstack and made it a pin.  The second smaller hole I simply created a 2.55 diam hole and placed it accordingly.  That seemed to work.  Thanks for the response.
rdl86626 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rdl86626 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2012 at 7:37am
Notes 3 and 4 are missing. Maybe use 1 padstack and a fill for the other. Do you have a pic of it?
Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote budnoel Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2012 at 6:59am
Hello - I need to create a mounting hole for a pin that requires two PTH's, a smaller one within the pad of a larger one.  I attempted to create a symbol using two padstacks and when I placed the second one I created a DRC error due to the overlapping of the two pads.  Anyone have any suggestions for how to create this symbol?  I've included a small section of the mfr dwg. to illustrate the issue.  Thanks in advance for any help.
This page was generated in 1.578 seconds.
