  New Posts New Posts RSS Feed - Comments field
Comments field
jameshead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameshead Quote  Post ReplyReply Direct Link To This Post Topic: Comments field
    Posted: 09 Jul 2012 at 3:18am
Sometimes the dimensions on a manufacturer's datasheet aren't complete enough for the entry boxes so the user has to make an educated guess, such as when a manufacturer only includes a minimum dimension, or only a maximum dimension, or leaves out a dimension so you have to use two others to work out the missing dimension.
It would be useful to have a "comments" field where a user could write some sensible notes in to be saved in the FPX file so that they can refer to them in the future or other users can see.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2012 at 1:58pm
I highly recommend that you add a new "Column" called "Comments" in the FPX file to type in your personal comments and messages as reminders.
