  New Posts New Posts RSS Feed - Filter By Selection
Filter By Selection
Randy Clemmons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy Clemmons Quote  Post ReplyReply Direct Link To This Post Topic: Filter By Selection
    Posted: 01 Jul 2012 at 1:12pm
Frequently I have trouble keeping track of which part I'm editing.
Keeping focused on the current part of interest would be much easier if there was a filter by selection feature, as shown below.
This is really the same functionality that "List All" gives us, but with significantly fewer steps.
To filter the current list using "List All"  we need to (Copy Cell > Select Find > Paste > Select List All)
more . . .
For example:
I would like to be able select a Part Number as shown above or any other cell.
Press the Filter Icon button and viola !
For example, the list is has been filtered to display rows with P/N = SN74V263-6GGM
Same functionality as list all, but at a fraction of the work involved.
Using this Filter Feature,  I could quickly edit the record (part) with a higher degree of certainty that I'm editing the correct part.
Randy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 2:14pm
So this is exactly like -
  • Find > Find what: > SN74V263-6GGM
  • List All
The "List All" feature removes all rows that do not have SN74V263-6GGM in the entire library.
There's also a "Look in:" feature to narrow the search filter to a single column to speed up the search.
I think you want the same feature but only use 2 clicks. Click once in the cell and click on the icon and the program does this -
  • Finds every occurance of that text
  • Only search in the column that the text is in
  • Eliminate every row that does not contain identical text
Then the "Show All" icon would return the entire list.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy Clemmons Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 2:37pm
Correct Tom,
"That's what I'm talking about" Big smile
This page was generated in 0.656 seconds.
