  New Posts New Posts RSS Feed - Add 'Thermal Pads on Assembly' Option
IanOnBass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IanOnBass Quote  Post ReplyReply Direct Link To This Post Topic: Add 'Thermal Pads on Assembly' Option
    Posted: 22 Jun 2012 at 6:55am
For footprints with thermal pads, add a 'Thermal Pads on Assembly' setting to allow separate settings to 'Pads on Assembly'.
I can envisage wanting filled pads for all but the thermal pads (where I might choose, either none or outline instead of filled), so that the Assembly layer Ref.Des is always visible.
Regards,
Ian
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2013 at 8:58am
For all component families that support Thermal Pads, select the "Settings" tab and use the drop-down "Tabs on Assembly".
Post Options Post Options   Thanks (0) Thanks(0)   Quote IanOnBass Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2013 at 1:17pm
Thanks for adding this feature!
I've been using it for a while ;-)
This page was generated in 0.672 seconds.
