  New Posts New Posts RSS Feed - Compact Silkscreen for Miniature Components
Message Reverse Sort Order
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Compact Silkscreen for Miniature Components
    Posted: 03 Jun 2026 at 10:45am
The Footprint Expert lets you easily modify the silkscreen for miniature components.
  1. You can turn off the wraparound silkscreen in 'Tools > Options > Drafting > Silkscreen'
  2. If you need a silkscreen outline you can add Drafting Lines
  3. You set the line shape, width, size, coordinates; put in one line and select 'New' and change the 'Y' to a negative value and Done - add to FPX.
