  New Posts New Posts RSS Feed - Inward L-Bend Terminal Leads for Pad Length
ransonjd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ransonjd Quote  Post ReplyReply Direct Link To This Post Topic: Inward L-Bend Terminal Leads for Pad Length
    Posted: 21 May 2026 at 10:48am
What is used to calculate the pad length on parts with inward bent leads?
(J-Lead, L-lead, PLCC, etc.)
As far as I can see, the software doesn't provide a field for the measurement of the inward extent of the leads on these parts. (Like L on SOPs, but inward.)
Additionally, what is E2 supposed to measure on an L-lead part?
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2026 at 11:37am
The Inward L-Bend is similar to the J-Lead component family but with flat leads that bend inward.
The E2 dimension is to the center of the terminal leads. You may have to do some math to figure that out.
This component family and terminal lead are in the new Footprint Expert Guideline which will be released next week.
