  New Posts New Posts RSS Feed - Footprint Expert 26.05 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Footprint Expert 26.05 Released!!
    Posted: 17 May 2026 at 11:16pm
Version 26.05 was just released!!
Fixes & Enhancements:
    • Removed through-hole pin terminal leads in the viewer display
    • When group moving pads on the component outline, the silkscreen wasn't trimming
  • Options:
    • Terminals:
      • Inward L-Lead: updated the 'heel' solder joint goals to match the documentation
      • Outward L-Lead: fine-tuned the Side solder joint goals
      • BGA updated the Courtyard Excess. The original settings were too robust.
    • Thermal Pad:
      • Can't change the 'Minimum Pattern to Pad Edge Space' to 0.00
      • Changed the paste mask maximum percentage from 99% to 100%
    • Changing the pad shape for Pin 1 and selecting the 'Change all Pin 1 shape - Yes' did not work properly
    • Drafting:
      • Courtyard - 'Apply Excess to Body/Pads' changed from Yes/No dropdowns to checkboxes
      • Origin - 'Target Diameter' has no effect and was removed (diameter size is automatically derived from crosshair line length).
  • Calculators:
    • CAPAE & Crystal - update the dimensions to accommodate Min/Max to be the same value
    • SOT23 Form Factor - updated the dropdown and the official Footprint Naming Convention document
    • SOD - fixed an issue with SOD footprints not loading due to adding the non-polarized version
    • Polarity dot location can be too close to body outline when placed to the side of pin one on some parts
      • Now moved to end of pad if this condition occurs
    • Library Manager was showing the wrong row count in the task bar after adding a new blank row or rows
    • Importing an fpx into another fpx file can sometimes throw an exception
  • CAD Tool Interfaces:
    • Pantheon - units in millimeters is not getting written to the output script file
This page was generated in 0.922 seconds.
