Set Courtyard Extension Dimensions |
pzt648485640
Joined: 02 Aug 2013 Location: shanghai Status: Offline Points: 90 |
Topic: Set Courtyard Extension DimensionsPosted: 20 Apr 2026 at 3:00am |
Currently, the Courtyard expansion is fixed at 0.2mm. Is it possible to specify a value of 0.1mm or 0.15mm? In practical scenarios—such as with mobile phone motherboards—a clearance of 0.1mm may be required.
Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 6075 |
Posted: 20 Apr 2026 at 8:09am |
Courtyard Excess is a user defined option in "Tools > Options > Terminals > Surface Mount'.
You can define different Courtyard Excess for every Chip Case Code. 01005, 0201, 0402, 0603, 0805, 1206, etc. can have unique Courtyard Excess. You can have multiple Option files for to create various PCB libraries for different applications. And you can define a Footprint Name Suffix for each application. You can create Option files for Flex (solder mask defined), Wave (larger solder joint goals), Rigid (Least, Nominal and Most density levels), with silkscreen for prototype and without silkscreen for production. With user defined Options there is no limit to the various libraries you can build. The FPX file is Component dimensions. Your Option files create the resulting patterns. |
