Forum Home Forum Home > PCB Footprint Expert > Features & Training > Standard Components
  New Posts New Posts RSS Feed - IPC-7352 Mathematical Model
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Topic: IPC-7352 Mathematical Model
    Posted: 5 hours 29 minutes ago at 5:06pm
This is an example of a 1206 Chip Resistor package.
Dimensions: H = 1.40, D = 3.20 ±0.20, E = 1.60 ±0.20, L = 0.50 ±0.25
The IPC-7352 mathematical model includes the D, E and L dimensions and tolerances and the solder joint goal settings for Toe = 0.35, Heel = 0.00, Side = 0.00
Resulting pad size rounded to 2 places is – L 1.15 x W 1.80 x G 1.80
The resulting pad stack pattern must have the terminal leads on the pad stack in these conditions:
The Nominal Material condition of the component package & Nominal Terminal.
The Minimum Material condition of the component package & Nominal Terminal.
The Maximum Material condition of the component package & Nominal Terminal.
The Minimum Material condition of the component package & Minimum Terminal.
The Maximum Material condition of the component package & Maximum Terminal.
The resulting pad stack must have terminal leads on the pad stack regardless of every possible Material Condition possible to pass assembly inspection and meet the requirements set forth in the IPC J-STD-001 Standard and the IPC-7352 Guideline in Figure 3-3 Profile Dimensioning.
i.e.: regardless of the Component Package and Terminal Lead Material Condition, the Terminal Lead must never be exposed outside the calculated pad stack.
This is proof that the V24 Footprint Expert mathematical model illustrated in the IPC-7352 guideline achieves that goal.
Note: most component packages are created in the Nominal Material Conditions. The package tolerances play a key role in the resulting pad stack. Nominal Package Dimensions & no Package Tolerances.
Solving for Lead Space
Definitions:
(All dimensions are in millimeters)
tol = tolerance
min = minimum, max = maximum
L = lead span, S = lead space
T = terminal length, W = terminal width
Example for a 1206 Chip
Lmax = 3.40, Lmin = 3.00, Ltol = length tolerance = Lmax – Lmin = 0.40
Tmax = 0.75, Tmin = 0.25, Ttol = terminal tolerance = Tmax – Tmin = 0.50
Wmax = 1.80, Wmin = 1.40, Wtol = width tolerance = Wmax – Wmin = 0.40
Smax = Lmax – (2 * Tmin) = 3.40 – (2 * 0.25) = 2.90
Smin = Lmin – (2 * Tmax) = 3.00 – (2 * 0.75) = 1.50
Stol (worst case) = Smax – Smin = 2.9 – 1.5 = 1.40
The worst-case difference between ‘Smin’ and ‘Smax’, 1.40, is statistically improbable since a simutaneous combination of extreme material conditions is considered beyond the actual range within which components are manufactured. To arrive at a more realistic tolerance range, the RMS (Root Mean Square) value is calculated using the tolerances on the dimensions involved.  In this case ‘L’ and ‘T’.
Stol (RMS) = RMS tolerance accumulation = √((Ltol ^2) + (2 * (Ttol ^2))
Stol (RMS) =  0.40 ^2 + (2 * 0.50 ^2) = 0.81
Sdiff = difference between Stol (worst case) and Stol (RMS)
Sdiff = Stol – Stol (RMS) = 1.40 – 0.81 = 0.59
To derive a new maximum and minimum dimension for ‘S’, in order to determine land patterns, half of ‘Sdiff’ is subtracted from ‘Smax’ and half the ‘Sdiff’ is added to the ‘Smin’. This technique is used so that more realistic ‘S’ limits are used in the land pattern equations for calculating the minimum land pattern gap between heel fillets.
Smax (RMS) = Smax – (Sdiff / 2) = 2.90 – (0.59 / 2) = 2.605
Smin (RMS) = Smin + (Sdiff / 2) = 1.50 + (0.59 / 2) = 1.795
Solving for Footprint
Definitions:
Zmax = pad span, Gmin = pad space
Jt = toe goal (outside fillet)
Tt = Toe tolerance
Jh = heel goal (inside fillet), Js = side goal (fillet)
Ht = heel tolerance
RMS = Root Mean Square
F = fabrication tolerance, P = placement tolerance
Example for the 1206 Chip
F & P were once considered as factors with typical values of F = 0.05 and P = 0.025.
They are set to zero in this example to reflect improvements in the fabrication and assembly processes and are included only to illustrate their place in the footprint calculation.
F = 0, P = 0
Jt = 0.35, Jh = 0, Js = 0
Tt =  Ltol ^2 + (2 * F) ^2 +(2 * P) ^2
Tt = √(0.4 ^2 + (2 * 0) ^2 + (2 * 0) ^2 = 0.4
Zmax = Lmin + (2 * Jt) + Tt
Zmax = 3.00 + (2 * 0.35) + 0.4 = 4.10
Ht = ((Smax(RMS) - Smin(RMS)) ^2 + (2 * F) ^2 + (2 * P) ^2)
Ht =  √((2.61-1.79) ^2 + 0 ^2 + 0 ^2 ) = 0.82
Gmin = Smax (RMS) -(2 * Jh) - Ht
Gmin = 2.61 - (2 * 0) – 0.82 = 1.79
Pad Size X = (Zmax – Gmin) / 2
Pad Size X = (4.10 – 1.79) / 2 = 1.15
Pad Center-to-Center C = Zmax - Pad Size X
Pad Center-to-Center C = 4.10 – 1.15 = 2.94
Pad Size Y = Wmin + (2 * Js) + Wtol
Pad Size Y = 1.40 + (2 * 0) + 0.40 = 1.80
Simplify your PCB design process with the Footprint Expert, the ultimate tool - it automatically applies this mathematical model and automates footprint and 3D model creation. Automation helps ensures accurate, consistent, reliable footprints with minimal introduction of human error. Let the Footprint Expert handle your CAD library so you can focus on creating flawless PCB designs faster and more efficiently!
Call:  847-557-2300
