  New Posts New Posts RSS Feed - How To Choose the Footprint for SMD Chip Resistor
Ariel_Levy View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ariel_Levy Quote  Post ReplyReply Direct Link To This Post Topic: How To Choose the Footprint for SMD Chip Resistor
    Posted: 22 Mar 2026 at 5:07am
How do you choose the footprint for SMD Resistor case 0402?
Vishay have 3 recommendations for footprints.
Yageo one recommended but it’s different from Vishay.
Vishay recommendation:
L=0.50 A=0.40 B=0.60
BASED ON IPC-7351
L=0.40 A=0.55 B=0.60
BASED ON IEC 61188-6-2
L=0.55 A=0.35 B=0.55
Yageo
L=0.50 A=0.50 B=0.60
I am very confused by all the recommendations.
I would appreciate a suggestion or any guidance on how to choose a footprint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2026 at 8:14am
IPC-7351 uses Min/Max Mode technology. the resulting footprint takes into consideration the package tolerances to calculate the pad stacks. The solder pattern should accommodate the package in the minimum, nominal and maximum material condition.
The average 0402 tolerance range is +/-0.05 to +/-0.10.
It seems like component manufacturers use their nominal package dimensions and add a Toe, Heel and Side. They use Nominal Mode technology and ignore the tolerances they provide in their datasheets.
The average dimensions on an 0402 are L=1.00, W=0.50, T=0.25.
Your pad stack pattern will depend on what dimensions and tolerances you use.
However, if you run into a 0402 chip manufacturer that has tolerances greater than 0.10, I would highly question the accuracy of their machine process.
Ideally, manufacturers try to produce packages that are Nominal Material Condition. That's the goal. Maybe in the future package tolerances will be 0.00 and then the Nominal Mode technology will take over and the IPC-7351 mathematical model will be history.
feynman View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote feynman Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2026 at 10:14am
Ask a/your assembler. They probably assembled millions of parts and are probably the best source for a reliable footprint.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ariel_Levy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2026 at 12:58am
Tom thank you very much Smile
and thank you Feynman
My difficulty is in obtaining information the thickness of the contacts size of the component (the size "T")
I bought the IPC-7351 and 7352. and you don't have information about this.
I think to buy EIA-JEP95 , and don't know it's worth the money if very MFG design is contacts size what "he" want's.
This table i found is accurate?
How you handle this with general discrete components ,when the contacts size can be between 0.10 to 0.40?
With the IPC-7351 when contacts size is 0.4 mm?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2026 at 8:46am
Here is the original EIA PDP-100 Chip Package dimensions and tolerances.
Compare with IEC.
