Chip Caps and Resistor w/No Terminal Tolerance |
pcbfreedomcad
Topic: Chip Caps and Resistor w/No Terminal TolerancePosted: 11 Mar 2026 at 5:14am |
What is entered in the tool for L and L1, when there is no tolerance for lead length given in the datasheet?
I am thinking of Chip Capacitor and Resistor terminal tolerances. |
Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 6064 |
Posted: 11 Mar 2026 at 8:31am |
When L and L1 dimensions are the same, only enter L (don't enter duplicate dimensions). L1 is optional if it's different than L. Then search for similar Case Codes from other manufacturers and see what their Terminal Lead Tolerances are. Sometimes the component manufacturer will only provide the Minimum dimension and you need to figure out the Maximum dimension. Average Terminal Tolerances for chip components by Case Code:
