  New Posts New Posts RSS Feed - PCB Model Selection Confirm - Molded Body
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Topic: PCB Model Selection Confirm - Molded Body
    Posted: 12 Feb 2026 at 10:56am
For this part” TAJB685M025RNJ” in this datasheet “http://download.siliconexpert.com/pdfs2/2026/1/22/22/20/26/9847155927/avx_/manual/taj.pdf
What PCB Model should we use to  create Footprint ?
Is it  “Molded Body”?  Correct or wrong
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2026 at 4:31pm
It is a 'Molded Body' package if the 'D1' dimension is at least 0.60 mm less than the 'D' dimension.
If the 'D1' dimension is less than 0.60 from the 'D' dimension, then it's an FP Designer footprint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2026 at 9:57pm
1. Please add more detail is that generic rules for similar case if the 'D1' dimension is less than 0.60 from the 'D' dimension, then it's an FP Designer footprint.
2. Also in FP tab, create it normal and after that choose to transfer to FP tab, or I must create it from scratch in FP tab
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2026 at 11:45am
If D1 is less than 0.60 then start in the Molded Body calculator with most of the dimensions and the mfr. recommended pattern.
Then move the footprint to FP Designer and fill out the 'Specifications' panel and edit the Body dimensions and pad stacks as needed.
