Gullwing SOT-23 Type Component Families |
| Author | ||||||||||||||||||||||||||||||||||||
Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 6073 |
Topic: Gullwing SOT-23 Type Component FamiliesPosted: 13 Jan 2026 at 1:19pm |
Here is a table that has the various SOT23 Type Packages.
In V26.02 you'll be able to select from a dropdown list of these SOT case codes and the SC version will also display. The user can enter any SOT*** case code in the dropdown window and it will change the Footprint Name and Physical Description. And the Library Editor will save and retrieve the updated data. Try it now - www.pcblibraries.com/downloads ![]() PCB Footprint Expert Simplify your PCB design process with the Footprint Expert, the ultimate tool for automating staggered pin BGAs. Automation helps ensures accurate, consistent, reliable footprints with minimal introduction of human error. Let the Footprint Expert handle your CAD library so you can focus on creating flawless PCB designs faster and more efficiently! Get your FREE Footprint Calculator or Footprint Expert Evaluation License: Call: 847-557-2300 |
