  New Posts New Posts RSS Feed - Silkscreen Offset Options
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Topic: Silkscreen Offset Options
    Posted: 21 Oct 2025 at 6:48am
Can provide more details, for the below and what is the impact on the silkscreen outline Map to body Margin?
Offset outline away from Package body.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2025 at 8:22am
There are several options for mapping silkscreen outlines.
Least, Nominal and Maximum body dimension.
Offset silkscreen away from Body. This makes the inner edge of the silkscreen outline the line origin (rather than the center of the line).
Margin will move the silkscreen outline away from the package Body by the value that you define. Some PCB designers want the silkscreen further away from the package body than the Maximum body outline. So they define an offset value.
This page was generated in 0.563 seconds.
