  New Posts New Posts RSS Feed - Footprint Expert Physical Description
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Topic: Footprint Expert Physical Description
    Posted: 14 Sep 2025 at 12:29am
I have noticed that as screen shows Footprint Name uses the D1 dimension instead of D.
Please can add more details, also how is the Physical Description generated?
Footprint Name: QFP50P1600X1600X120-100
Physical Description:
Quad Flat Pack (QFP), 0.50 mm pitch; 100 pin, square, 25 pin X 25 pin, 14.00 mm L X 14.00 mm W X 1.20 mm H body
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2025 at 8:47am
The footprint name describes the outer dimensions of the package.
The 16.00 mm = the Lead Span per the IPC-7351 Naming Convention Guidelines.
The 14.00 mm = the Physical Description of the Package Body (doesn't include the terminal leads, just the package body dimensions).
