  New Posts New Posts RSS Feed - Adding Template Altium Footprint Builder
Post Options Post Options   Thanks (1) Thanks(1)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Topic: Adding Template Altium Footprint Builder
    Posted: 03 Sep 2025 at 7:43am
Adding Template to Altium Footprint Builder, to have one script .prjscr file for each package have all parameters when using 'Batch Build'.
When selecting Batch Build create multiple Libraries when 'Create New' option is selected instead of building one by one like other tool like Altium as attached, can build more footprints, it will save time uploads/11979/BGA_Ball_Grid_Array.xls
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2025 at 9:43am
We're looking into this request via Altium scripting.
We're not sure there is an Altium script command that can do this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2025 at 11:42am
Thanks Tom
And waiting your updates
There are about 38 templates in Altium as I sent one as sample
Please double check for adding this option in expert tool it will be more helpful
BTW I have explained this before to Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2025 at 12:43pm
This request is a bit over the top. It's impractical from a programming point.
You want to automate the creation of multiple libraries (one library per footprint) when using 'Batch Build > Create New'.
If this is what you need for your PCB library process, we recommend that you build one part at a time and create a new library for every footprint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2025 at 11:25pm
No, not when using batch build.
When using build  single footprint, instead fill dimension in interface like below screen, upload Excel .xls file contains all these values, and in same time user can have option upload more footprints with different dimension but same package, and tool create them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2025 at 2:59pm
can please check my last reply and let me know your thoughts about that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2025 at 3:18pm
If I understand your request correctly, you want a feature to allow 'Batch Build' to automatically create a separate Altium library for every footprint in the Batch Build.
I don't think this is going to happen.
You'll have to use "Single" part creation to autogenerate a new library for each part. Footprint Expert already has this feature.
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2025 at 12:07am
I don't mean this.
I meant the creation of a footprint to have an option instead fill dimension one by one, to have Excel file for each package type, and user fill them once and upload them, it will be great, effective, productive, avoiding more time to be duplicated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2025 at 1:38am
I hope to check this , request, i think it will be so great  to be added in tool , however it may take effort from SW point of view, but really it will be more helpful , grateful supportive and productive
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2025 at 8:19am
We're confused on the word 'Template'.
If you're requesting a new feature and we don't understand the request, we need you to develop a test case and explain step by step how this feature can be implemented.
Especially when no one else asked for this feature.
This page was generated in 0.343 seconds.
