  New Posts New Posts RSS Feed - Adding Minimum Annular Ring for Keepout
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Topic: Adding Minimum Annular Ring for Keepout
    Posted: 03 Sep 2025 at 7:41am
Add a minimum annular ring for keep-out for non-plated holes in 'Tools > Options > Terminals > Through-hole'.
The current method of making the non-plated hole keep-out the same size as the Anti-pad does not work it you need a keep-out clearance larger or smaller than the Anti-pad.
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2025 at 11:27pm
can this feature be added in option file like what be proposed for keep out diameter
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2025 at 10:59am
Only connectors have non-plated holes.
We know you want this to be automatic, but this would force every Footprint Expert user to manually update the Options. Right now it's on automatic per the same size as the Anti-pad and that's the way it's been for the past 20 years.
You can edit the pad stack keep-out in the Pad Stack Manager.
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2025 at 12:09pm
Thanks, Tom
i have 2 points
1- not every user need to update option file manually, like any other feature there is default values, so if user doesn't want change default, will leave it with no change, and if user want change , will have ability to change, it will be great idea
2- from shown screen how i control min annular ring, for example if want make it 0.635
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2025 at 1:00pm
Making the non-plated keep-out size smaller than the plane anti-pad is not good PCB design practice.
Your signal traces need a clean return path on the GND plane.
We like to prevent traces from running over a Plane Anti-pad.
Your request for this feature was declined based on good PCB design principles and guidelines.
