Forum Home Forum Home > PCB Footprint Expert > Features & Training > FP Designer
  New Posts New Posts RSS Feed - Customizing Thermal Pad Paste Mask
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Customizing Thermal Pad Paste Mask
    Posted: 02 Sep 2025 at 4:08pm
If you need to customize the paste mask on your thermal pad, you can do this easily by moving your standard calculator-built part into the Footprint Expert FP Designer module.
The SMD Calculators only produce rectangle shape thermal pad paste mask.
You can fully edit pad stacks in FP Designer.
Use the Calculator to produce the master pattern used for the 3D STEP model.
Move the Calculator footprint to FP Designer.
Select the Pad Stack Manager
Edit the thermal pad stack > paste mask > radius > Save Changes > Close
Edit Specifications > enter manufacturer name > case code > OK > Finish > Add to FPX
Simplify your PCB design process with the Footprint Expert, the ultimate library automation tool! Automation helps ensures accurate, consistent, reliable footprints with minimal introduction of human error. Let the Footprint Expert handle your CAD library so you can focus on creating flawless PCB designs faster and more efficiently!
Call:  847-557-2300
