Forum Home Forum Home > PCB Footprint Expert > Features & Training > FP Designer
  New Posts New Posts RSS Feed - Complex BGAs in Minutes!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Complex BGAs in Minutes!
    Posted: 30 Aug 2025 at 5:39am
The Footprint Expert's "FP Designer" module can automatically build BGAs with up to 99,999 pins by importing CSV files.
You can import this .TXT file into FP Designer:
  1. Select FP Designer
  2. Create the Body – 31 x 24 x 2
  3. Create a round 0.30 mm SMD pad stack
  4. Import the .txt file
In Footprint Expert, go to:
Help > FP Designer > Place Pins with CSV File - BGA
(or see online version here)
Simplify your PCB design process with the Footprint Expert, the ultimate tool for automating staggered pin BGAs. Automation helps ensures accurate, consistent, reliable footprints with minimal introduction of human error. Let the Footprint Expert handle your CAD library so you can focus on creating flawless PCB designs faster and more efficiently!
Call:  847-557-2300
