  New Posts New Posts RSS Feed - Footprint Expert 25.09 Released!!
Message Reverse Sort Order
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Footprint Expert 25.09 Released!!
    Posted: 16 Aug 2025 at 11:51am
Version 25.09 was just released!!
Fixes & Enhancements:
  • 4K Monitors
    • Mouse Wheel scrolling resized the program in certain scenarios
    • Selecting one object after another no longer requires to close an open dialog box
    • Improved the Highlight cell feature when searching for duplicate part numbers
  • Calculators:
    • Round keep outs not saving to fpx library or translating correctly
    • PLCC – changed the default pad shape to Oblong due to colliding corner pins
    • SOT143 – removed the pin quantity from the Footprint Name
    • BGA – the Footprint Naming Convention for IPC-7351B added a Ball Diameter Suffix
    • Mounting Holes:
      • Vias in mounting hole causing problems with count in both Min/Max and Nominal calculation modes
      • Opening parts from FPX library not opening correctly
      • Non-Plated Mounting Target Origin size was not syncing with Options
    • Through-hole Footprint Naming Convention used the 'Nominal' lead diameter. Changed to 'Maximum'
    • Footprint naming for parts with hidden or removed pins get a hyphen instead of an underscore
    • Certain Thermal Tab sizes patterns allowing the pattern to overlap the pad
    • Thermal Tab name for pad stack and pad not receiving the pattern name string
  • Pad Stacks:
    • Thermal pad 'Pad Stack' name was missing the p4x value
  • 3D STEP:
    • SON – The Polarity Dot color did not adhere to the assigned color
  • CAD Tool Interfaces:
    • Xpedition:
      • Update text font to vf_std
    • Altium:
      • Changed UI text from 'Enable All Layers' to 'Enable Only Used Layers'
    • KiCad:
      • Manually inserted keepout was not translating properly
