  New Posts New Posts RSS Feed - DFN and PSON footprint differences
dramos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dramos Quote  Post ReplyReply Direct Link To This Post Topic: DFN and PSON footprint differences
    Posted: 16 Jun 2025 at 11:10pm
Hi Tom and Team,
When I am creating footprints I have as a rule of thumb, to use rounded rectangle pads except for DFN, LGA, PQFN and Thermal pads. For this footprints I use rectangle pads
What about PSON? I think that this footprint has the pads underneath the body as a DFN and It should use a rectangle pad, as well.
What is the default recommendation for this footprint type?
Regards,
david
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2025 at 7:13am
PSON is the same as PQFN as both have Pull-Back leads under the package body.
PSON/PQFN terminal leads come is 2 shapes.
  1. Rectangular Lead = Rectangular Pad
  2. D-Shaped Lead = Rounded Rectangle Pad
LGAs have 2 terminal lead shapes.
  1. Square Lead - Square Pad
  2. Round Lead = Round Pad
DFNs have rectangular leads
Thermal Terminal Leads come in 2 shapes.
  1. Rectangular
  2. Rounded Rectangular
Post Options Post Options   Thanks (0) Thanks(0)   Quote dramos Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2025 at 10:33pm
Many thanks for the explanation!
I am working on the Calculator Option File, and I would like to share with you one idea.
When we are configuring the default Pin1 orientation, Pad shape... In the Components-Surface Mount , Would be very crazy - no sense idea - to separate into two different options the QFN and PQFN. SON and PSON is another example.
The reason is the next, if we have a PQFN component with rectangular leads of course we will use a rectangular pad, but if we have a QFN footprint with a rectangular lead perhaps would be interesting to use a rounded rectangle pad.
Thanks for your comments.
Best regards,
david
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2025 at 9:01am
Is this a New Feature Request?
If so, you're in the wrong Forum Thread. Go here -
The component families are grouped together for easy code changes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dramos Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2025 at 2:59pm
It was not a Feature Request at the beginning of all...
But as I realized that the Option configuration could create confusion between the users, YES I will add it as Request improvement of the program.
Best regards,
david
