  New Posts New Posts RSS Feed - Footprint Expert 25.06 Released!!
Message Reverse Sort Order
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Footprint Expert 25.06 Released!!
    Posted: 01 May 2025 at 5:35pm
Version 25.06 was just released!!
Fixes & Enhancements:
  • CAD Tool Translators:
    • Pantheon - Added mil units to the translator
    • DipTrace - Limited the interface to allow PADS ASCII 2005 and VX
    • Altium - New Altium 'Enable All Layers' checkbox option added - defaults to checked = enable all layers for viewing
  • Pad Stack Designer:
    • Solder Mask excess not working with Inch Units
    • Added the ability to Corner Radius square through-hole pad stacks
  • Options:
    • Updated Drafting > Silkscreen > Ref Des Line Width to allow a Zero '0' value
  • Calculators:
    • Multiple Component Families - missing the 'L' suffix when using the IPC-7352 footprint naming convention
    • Local Option for Drafting > Assembly > Ref Des - Min/Max values were swapped
    • PLCC - when opening an FPX into the viewer the 'D' and 'E' min/max dimensions were nominal
    • New Search option for Case Code, Manufacturer and Part Number cells
      • To use - select Right Mouse Button
      • Options include - Internet Browser, Parts on Demand (POD) and Manufacturer's Home Page
This page was generated in 0.326 seconds.
