  New Posts New Posts RSS Feed - are this two footprints similar?
dramos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dramos Quote  Post ReplyReply Direct Link To This Post Topic: are this two footprints similar?
    Posted: 15 Jan 2025 at 3:47am
Dear Tom and Team,
I have been creating a new footprint for my TI TPS22917 and when I was going to save it on my library I realized that previously I created a footprint with the same name, WE 824015.
From your point of view are both footprints similar?
they have a difference on the pad but the name of the footprint is similar.
In both cases I used Footprint Expert 24.11. Attached you will find the components and data sheets.
Thanks for your comments.
Best regards,
David
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2025 at 9:06am
The Mfr. Recommended Patterns are almost the same dimensions.
Download the parts from www.pcblibraries.com/POD ;
Texas Instruments - TPS22917DBVR
Wurth - 824015
The only difference is the "G" dimension is 0.10 difference.
