  New Posts New Posts RSS Feed - Custom Courtyard option
Bharat_Verma View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bharat_Verma Quote  Post ReplyReply Direct Link To This Post Topic: Custom Courtyard option
    Posted: 28 Nov 2024 at 9:24pm
This is regarding Custom courtyard for some exceptional components which does not occupy the full space of defined pads as their body is smaller but pads exist have long distance.
Between the Two pads there is lots of space where designer can place another small components.
Example : 1612618-1
I have sent you an Email with Image . It would be great if you can suggest something useful.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2025 at 12:15pm
There is an Option feature in "Tools > Options > Drafting > Courtyard > Minimum Contour Cut-in Gap".
The default setting is 5 mm but you can change the value to whatever you want and the courtyard will cut in-between pads.
