  New Posts New Posts RSS Feed - Land pattern name for melf resistor
magnus.lictor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote magnus.lictor Quote  Post ReplyReply Direct Link To This Post Topic: Land pattern name for melf resistor
    Posted: 06 Nov 2024 at 1:57am
HI,
I am creating a landpattern for a melf resistor.  According to the landpattern naming conventions the pattern name for a melf resistor is ;
RESMELF + Body Length + Diameter + L Lead Width
Looking at the generated name for the landpattern, it uses the nominal dimensions for the body lenght and the lead width and the maximum dimension for the diameter.
I also would expect the nominal diameter there.
Regards, Charles
