  New Posts New Posts RSS Feed - FP Calculator Silkscreen Issue
kvkoskin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kvkoskin Quote  Post ReplyReply Direct Link To This Post Topic: FP Calculator Silkscreen Issue
    Posted: 12 Sep 2024 at 4:15am
Hello!
I'm making a footprint for the nRF9151 with FP Calculator. There seems to be some calculation issue with the silkscreen clearance.
This is the silkscreen with 0.200 mm offset:
Clearance 0.200mm
This is with 0.199 mm offset.
The pins are 0.20 mm from the component edges.
Why silkscreen is removed from left and right edges with default settings?
This is done with "v.11, 9/6/2024". Happy to provide further info as needed.
