  New Posts New Posts RSS Feed - Question About Dimensions Being Rounded-off in IPC
elibu123 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote elibu123 Quote  Post ReplyReply Direct Link To This Post Topic: Question About Dimensions Being Rounded-off in IPC
    Posted: 28 Aug 2024 at 12:40pm
Hello Everyone,
I have a question regarding the rounding of dimensions based on the IPC-7351B standard for land pattern calculations.
Shouldn't the dimensions being rounded off be the final land pattern dimensions—overall length of the land pattern (Z), distance between lands in the pattern (G), and width of the land pattern (X)? Why is Library Expert rounding off the pad-to-pad spacing (C) and pad length (Y) instead?
Thank you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2024 at 1:44pm
Everything is explained in the new V24.10 Footprint Expert "Help > User Guide".
