  New Posts New Posts RSS Feed - Footprint Expert 24.10 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Footprint Expert 24.10 Released!!
    Posted: 14 Aug 2024 at 1:37pm
Version 24.10 was just released!!
Fixes & Enhancements:
  • Help > User Guide:
    • Several updates were made to match the current Footprint Expert release
    • Updated the pad stack and pad names for IPC-7352 version
    • Pad Stack name updated for SMD edge connectors that require a Top & Bottom pad
  • Options:
    • Doubled the "Under Body Outward L Lead" Courtyard Excess for Height > 10 mm
    • Updated the Terminals > SOP > Pitch from 0.65 to 0.625 to match the IPC-7351B table
  • Calculators:
    • QFN with no Thermal Pad - added longer Pin 1 and removed the "Set Pin 1" feature
    • SOT23 - User notice added when Gullwing is automatically changed to Outward L.
  • CAD Tool Interfaces:
    • EAGLE changed to Autodesk Fusion/Eagle
    • eCADSTAR - added Pad Naming option back for CR-5000 and IPC-7351
    • Cadence - fixed a typo for V16.5 (was 15.5)
This page was generated in 0.813 seconds.
