  New Posts New Posts RSS Feed - Outward L Leads
Outward L Leads
Alex Quilty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex Quilty Quote  Post ReplyReply Direct Link To This Post Topic: Outward L Leads
    Posted: 13 Jun 2024 at 5:43am
Hey Tom,
Quick moment to thank you for all of the resources you provide to us! It has really helped me in understanding some of the IPC standards and what they are all about.
Anyway, one of the resources you provide us is the IPC Solder Joint Goal Tables (SJGT) in one of the Excel Files.
I noticed that in PCB Libraries most of your SOTs use the Gullwing SOT SJGT.
So, what is the point of the Outward L SJGT?
In your excel file, you have it pictured with a SOT23-8, but in the software, all of the SOTs just use the Gullwing SJGT instead of the Outward L Lead SJGT.
Is it remanent of past IPC 7351 standards?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2024 at 8:39am
Yes, there is a footnote in the IPC-7351B gullwing lead table for Outward L-bend.
The Outward L-Bend is when the gullwing lead does not have an angled lead. The terminal lead comes out of the component and goes straight down and then bends flat.
SOTs use this lead form a lot and there's a built in formula for calculating the difference between an Outward L and Gullwing terminal lead. The main difference between the two terminal leads is the "Heel" goal is smaller in the Outward L-Bend.
The Excel spreadsheet "Footprint Expert Solder Joint Goal Tables" is derived from IPC J-STD-001.
