  New Posts New Posts RSS Feed - Footprint Expert Display Resolution
almhuq75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote almhuq75 Quote  Post ReplyReply Direct Link To This Post Topic: Footprint Expert Display Resolution
    Posted: 18 Apr 2024 at 11:37am
Hi all,
I have a 32-inch monitor with a graphics card set to 3840x2160 resolution.
As a result, all the text, component data, and library window text are extremely small.
I changed the resolution of my monitor to 1920 x 1080 and the windows on my PCB Footprint expert did not get bigger and the text was still quite blurry and small.
Is there a way you could increase the font size of all the text in the PCB Footprint expert program.
-Al
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2024 at 12:11pm
Read the "Help > User Guide > Getting Started > Display Issue".
WilliamsimC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WilliamsimC Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2024 at 2:25am
Hi Al,
It sounds like you're experiencing a common issue with high-resolution displays where text and interface elements appear too small. Changing the monitor's resolution isn't always the best solution, as it can result in blurry text, as you've noticed.
Instead, try adjusting the scaling settings in your operating system. For Windows, go to 'Display Settings' and look for 'Scale and Layout'. Here, you can increase the size of text, apps, and other items without changing the resolution. If you're using a Mac, go to 'System Preferences', select 'Displays', then 'Scaled', and choose a larger text option.
If the PCB Footprint Expert program has its own display settings, check there for font size adjustments. Some programs allow you to customize the text size independently of the system settings.
Remember, each program may have different ways to adjust the display, so consult the software's help resources if needed.
