  New Posts New Posts RSS Feed - 3D STEP Models For Electronic Component Packages
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Topic: 3D STEP Models For Electronic Component Packages
    Posted: 07 Apr 2024 at 2:44pm
Here is a sample of 3D STEP models created by Footprint Expert.
These models are auto-generated using the package dimensions in the Surface Mount and Through-hole calculators. You can change the color assignments for the package body, polarity marker, and terminal leads and save the colors to the FPX library.
You also have 100% control of the through-hole lead length to accommodate different PCB thicknesses.
