  New Posts New Posts RSS Feed - IPC-7351 Collapsing and Non-Collapsing BGA Balls
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Topic: IPC-7351 Collapsing and Non-Collapsing BGA Balls
    Posted: 07 Apr 2024 at 1:31pm
IPC has a rule for BGA pad size tolerances. They take a Nominal Ball and reduce or increase the pad size by a percentage, then add a pad size tolerance (variation). IPC-7351 recommends using the Maximum Material Condition of the Variation.
All BGA balls collapse. Non-collapsing BGA balls are created by the PCB librarian by solder mask defined pads or making the pad size larger than the Ball.
Collapsing Ball.
Non-Collapsing Ball defined by Solder Mask.
IPC-7351 BGA tables for pad size reduction for collapsing balls and pad size increase for non-collapsing balls. The pad size increase is normally used for fine pitch BGA's that require via-in-pad technology for fanout.
There are 3 Density Levels A, B and C that indicate the percentage amount for pad size calculation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2024 at 1:39pm
The Solder Mask Defined BGA pad helps secure the pad to the prepreg. This helps during drop tests.
mking View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote mking Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2025 at 11:39am
For the collapsing BGA ball with a diameter between the values listed what is appropriate reduction?
My example is a 0.242 mm diameter. Is the recommended reduction 15%, 20%, or 19.2% (linear interpolation)?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2025 at 1:38pm
If the Ball diameter is on the dividing row between percentages the new ball size will take the lower values.
Here is a sample BGA terminal option table where the 0.24 mm Ball Diameter was added.
This page was generated in 0.488 seconds.
