  New Posts New Posts RSS Feed - Radial Mounted Resistors
phil.holden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phil.holden Quote  Post ReplyReply Direct Link To This Post Topic: Radial Mounted Resistors
    Posted: 10 Aug 2023 at 2:45am
Does anybody have any suggestions for creating Radial Mounted resistors in Library Expert?
I have had to use Axial and adjust the dimensions but the model looks pretty crazy Sleepy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2023 at 7:31am
Are you referring to Horizontal or Vertical mounted axial resistors?
Horizontal - use the through-hole Axial calculator. The 3D model is accurate.
Vertical - use FP Designer / Radial. The 3D model is an extruded block.
