Silkscreen Outline to Footrprint |
c.utrera
Topic: Silkscreen Outline to FootrprintPosted: 09 Aug 2023 at 3:58am |
Hi, The problem is that I initally have checked in my "Master Options" under Options > Drafting > Silkscreen Outlines and Text > All Density Levels the box "Add Outline to Footprint" since I want by default a silkscreen in all my designs. But for smaller footprints ( ie. capacitors, resistors 0402, 0603) I don´t want the default silkscreen created. Why? Becayse the silkscreen is to small to be printed in the sides of the pads between the gap, and the tool generates a "C" form shape around the pads. For me it is a problem because if the routed signal in the top or bottom layer is a high speed signal the silkscreen could affect the signal integrity. So I want it deleted. Therefore, I change it in the particular menu in the calculator unchecking this box and I update it pushing Calculate. In the Footprint dialog the footprint appears to be updated. I then proceed to Add to Library and when I open it from the library the Silkscreen is still there. It looks like the property for the silkscreen is being inherit even when I specifically tell it not to do so. Can you please orientate me to check if there could be anything I am missing in the process?
Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 6070 |
Posted: 09 Aug 2023 at 7:32am |
In "Tools > Options > Drafting > All Density Levels > Allow Alternate Outline (when geometry is too small for default outline)"
Uncheck the box and you will not get silkscreen outlines on 0201, 0404 or any small package.
c.utrera
Posted: 11 Aug 2023 at 2:58am |
Thanks! It worked for the 0201, 0402 chips. But for example I had a component that is not a chip. A DFN Crystal, and after changing the property you mentioned the silkscreen outline dissapeared. Somehow the tool considered the silkscreen was too small but I want the silkscreen in that particular component to appear. I tried the same I mentioned in my original post, I changed it in the particular menu in the calculator unchecking the box you mentioned and I updated it pushing "Calculate". Then the silkscreen appeared. I updated the library but somehow when I reload the footprint my changes disappear. Is this normal behaviour?
Posted: 11 Aug 2023 at 8:37am |
No room for silkscreen means that the calculator will try to add a silkscreen but if it violates the Gap Rule, it will not add the silkscreen.
There are 2 workarounds.
