  New Posts New Posts RSS Feed - Cylindrical End Cap Devices - Toe/Heel/Side Goals
jde0503 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jde0503 Quote  Post ReplyReply Direct Link To This Post Topic: Cylindrical End Cap Devices - Toe/Heel/Side Goals
    Posted: 20 Jul 2023 at 9:40am
Devices with Cylindrical End Cap terminations should have different groups of toe/heel/side solder goals based on device height/length/width.
This has been done with rectangular end cap devices and should similarly be done for cylindrical.
There's no reason to have a part that is twice the size have the same toe/heel/side solder goals. This leads to wildly undersized or oversized pads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2023 at 9:37am
We granted your wish and turned MELF solder joint goals into incremental pad stacks per the Nominal Diameter in V24.02 pre-release dated today 12/22/2023.
New Nominal Diameter Ranges –
  • Dia. < 1.00
  • Dia. >= 1.00, < 2.00
  • Dia. >= 2.00, < 3.00
  • Dia. >= 3.00, < 4.00
  • Dia. > 4.00
Now you can control the Toe, Heel and Side for MELF Resistors, Diodes and Fuses.
Thank you for recommending this feature.
V24.02 will be officially released next week - www.pcblibraries.com/downloads
