  New Posts New Posts RSS Feed - Footprint Expert 23.09 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Footprint Expert 23.09 Released!!
    Posted: 01 Jul 2023 at 4:12pm
Version 23.09 was just released!!
Fixes & Enhancements:
  • CAD Tool Interfaces:
    • Siemens PADS Standard – when in the translator menu, changing output from Decal to Decal and Part Type crashed the program
  • Cadence Allegro/OrCAD PCB:
    • Translator bug that was corrupting pad stacks with arc corners
    • Device type label mini class subtype changed from “DEVICE TYPE” to “COMPONENT VALUE” with text of “VALUE”
    • Symbol type for fiducials and mounting holes changed from “Package Symbol” to Mechanical Symbol”
    • Added “Footprint Properties Lock” option
    • Added label size to text_block converter
    • Application of “OrCAD designer basics” checkbox function restored
    • The Component Outline also turned off when the Silkscreen Outline was unchecked
    • Duplication of mechanical pins in FP Designer
    • Pad Stack Designer – in certain cases, the through-hole pad stacks were not following the minimum annular ring setting in Options
    • Silkscreen and Assembly outlines not following Option Settings
  • Calculators:
    • Axial Lead – Added missing ‘optional’ indicator note to Axial GUI
    • HC49 Through-hole Crystal – updated the Physical Description. Swapped “T” and “W” references
