  New Posts New Posts RSS Feed - FP Designer
FP Designer
jmeinert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmeinert Quote  Post ReplyReply Direct Link To This Post Topic: FP Designer
    Posted: 18 Apr 2023 at 6:39am
Why when bringing in a downloaded footprint into FP Designer are my courtyard excess preferences not set?
And it sure would be nice to have a solder mask preference so that I don't forget to added.
It also would have to be set on a download footprint.
Jeff
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2023 at 7:48am
In FP Designer you open the footprint that you downloaded and then select the Options panel to change the Courtyard Excess to whatever you want and resave the footprint back to FPX.
FP Designer does follow your Option file when you create a footprint from scratch.
If you download a footprint, the solder mask settings are pre-defined and if you want to change the solder mask, select the Edit Pad Stack toolbar button and open the Pad Stack Manager.
I'll discuss this issue with the programmer for that piece of code, but we follow the guidelines provided by the component manufacturer and I'm not sure we want to override that setting.
