  New Posts New Posts RSS Feed - What TEMPLATE to use?
wheelee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheelee Quote  Post ReplyReply Direct Link To This Post Topic: What TEMPLATE to use?
    Posted: 28 Feb 2023 at 8:25pm
Which Template to use for these parts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2023 at 9:05am
You use FP Designer to create the base land pattern for pins 1 - 8.
Pin 9 is the thermal pad and it's created as a rectangle of the outer extents.
Edit Pin 9 to add the cut-ins in your CAD tool.
Or buy POD Credits and we'll build this footprint for $10 in FPX format with same day turnaround.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheelee Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2023 at 7:09pm
OK, thanks Tom, will try it in Designer.
