  New Posts New Posts RSS Feed - Footprint Expert 23.04 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Footprint Expert 23.04 Released!!
    Posted: 21 Feb 2023 at 5:57pm
Version 23.04 was just released!!
Fixes & Enhancements:
    • Updated all non-plated holes to "Mechanical" pins
    • Fixed an issue with the non-plated hole with an annular ring pad
    • Removed annular size options from the non-plated pad stack Keepout
    • Pin Placement Wizard getting non-metric calculated values wrong
    • Non-plated annular pad stack selection should result in a 'Mechanical' pin application
    • Keep outs not required for Annular non-plated pad stacks
  • Calculators:
    • Right Angle Headers – Added a default Pin Pattern image needs to show something when it's an option
    • DIP Socket: Pin 1 Polarity Dot was in the wrong location
    • SODFL: Assembly label orientation was wrong
  • Options:
    • Add new feature for silkscreen outlines to allow the user to have a full body or hatched silkscreen
      • All Right-Angle Headers – Post, Receptacle, Shrouded
      • All Grid Array packages – BGA, CGA, LGA, PGA
      • DIP Socket
      • SIP
      • Axial
      • Radial Rectangle – Dipped, Disk, Molded, LED
    • Comma added after "(_GA)," in grid array Physical Descriptions
    • Updating a Footprint to library updates multiple lines under certain conditions
