  New Posts New Posts RSS Feed - Component Category. Which one?
mperry1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mperry1 Quote  Post ReplyReply Direct Link To This Post Topic: Component Category. Which one?
    Posted: 10 Feb 2023 at 10:15am
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2023 at 10:58am
SON with Thermal.
The package has 2 Thermal Tabs but you only create one.
Then move the Footprint to FP Designer to relocate (offset) the one Thermal Pad (pin 9) and add the second thermal pad (pin 10).
Then update the Specifications panel with the mfr. name, Case Code, Part Number and select OK.
The select Add to Library.
