  New Posts New Posts RSS Feed - Footprint Expert 23.03 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Footprint Expert 23.03 Released!!
    Posted: 07 Feb 2023 at 12:17am
Version 23.03 was just released!!
Fixes & Enhancements:
  • Calculators:
    • New Feature: Right Mouse Button no longer required to toggle between feature selection
    • Molded Body LED: not following Option settings for alpha pin names
    • Mounting Holes: when saving mounting hole data to the FPX library, retrieving the data grayed out the “E1” dimension
    • Flange Mount Vertical: updated the Pin 1 Polarity Dot location
    • Corner Concave Oscillator: the silkscreen outlines for the “D” and “E” dimensions were swapped
    • Dip Socket: round lead option not working
  • 3D STEP:
    • Chip, Molded and Side Concave LED and default terminal color options are cross connected
    • When opening a new FPX library, the library name does not immediately change
  • Drafting Symbols/Shapes:
    • When entering data in the menu, the Line Width defaulted back to the original setting when any other cell was edited
    • When selecting the “New” button, the Centroid X dimension automatically changed to 0.00
    • Added new feature for adding a single pad stack
    • Updated the Radial Pin Placement feature
    • When adding a new footprint to the FPX library, the “Save to Library” button turned off
  • CAD Translators:
    • Altium: Added new code to streamline the Altium translator
  • Footprint Expert Pro:
    • Fixed the banner popup ads to not show when the program in minimized
