  New Posts New Posts RSS Feed - Footprint Expert 23.01 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Footprint Expert 23.01 Released!!
    Posted: 02 Jan 2023 at 2:33am
Version 23.01 was just released!!
Fixes & Enhancements:
  • Console Options:
    • Added IPC-7352 Naming Convention
  • Calculators:
    • 2-Pin DFN – updated the assembly outline polarity marker from upper left to lower left
    • Physical Description – updated QFN, PQFN, SON, PSON, QFP & SOP to add a comma after the closed parentheses
  • Options:
    • Pad Stack Rules – Corner Rounding > Corner Radius Limit – changing the value to 0.00 now results in a rectangle pad
    • These FPX columns were removed – Symbol Name, Pin Quantity, Value, Tolerance, Voltage, STEP File Name
      • You can manually remove these columns from your master FPX file
    • New Feature – Middle mouse wheel zoom now zooms wherever the cursor is
  • FPX File Converter:
    • Updated to the new V23 format both internally and the separate .exe version
    • Enhanced the Import .CSV file feature
  • CAD Tool Translators:
    • Altium – fixed an issue with pad place round-offs for 0.65 mm Pin Pitch parts
    • Allegro – 3D STEP file was not placed in the correct directory folder
  • Footprint Expert Viewer:
    • This free edition of the Footprint Expert was discontinued, but the Enterprise version runs as a Viewer when no license is found
  • POD Builder:
