  New Posts New Posts RSS Feed - Footprint Expert 2022.13 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Footprint Expert 2022.13 Released!!
    Posted: 23 Oct 2022 at 3:56pm
2022.13 was just released!!
Fixes & Enhancements:
  • Calculators:
    • New – added a 6-pin version of the Side Concave Package
    • Mounting Hole – removed “A” (for annular) from mounting hole name
    • DFN 4-pin:
      • Pad to Pad Clearance bug not following Options rule
      • Option to expand silkscreen outline
    • Axial Lead – Body Diameter uses height (A) instead of diameter (E) dimension
    • SOL – Width uses Body width (E1) instead of Lead Span (E) dimension
    • Corrected Mfr. Dimensions' roundoffs for place and pad size round offs
    • Corrected paste mask percent-to-excess calculation
    • Round-To function for TH pad stacks resolved for non-millimeter units
    • Courtyard relation to pads with zero excess
    • Symbol & Keepout rectangle shape orientations now rotate properly with the footprint
    • New – added pin orientation to FP Designer pin placement import .csv file
    • Pad Stack Designer – hole size round off and non-plated hole mask pad stack name
    • Move Origin by Coordinates not recognizing other than mm units
    • Ref Des for Silkscreen and Assembly label orientations synced
    • Zero values in the pin-place text boxes
  • Options:
    • Options/Pad Place Units not saving
  • CAD Tool Translators:
    • Altium – added feature that automatically opens the output folder if the user wants to
    • Exception thrown when a library is loaded when there are no data grid rows showing
