  New Posts New Posts RSS Feed - Footprint Expert 2022.11 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Footprint Expert 2022.11 Released!!
    Posted: 23 Aug 2022 at 12:01pm
2022.11 was just released!!
Updates & Bugs Fixed:
    • The Physical Description pin quantity was producing incorrect values when pins were Deleted or Hidden
    • Utilities > Regenerate Library > Physical Descriptions did not work correctly for Mounting Holes
    • Headers – Physical Description was changed from # Pins to # Pin
    • Improved auto silkscreen trimming and pad placement
    • Pad Stack Editor – when selecting SMD Pad Shape “Both”, the Chamfer size was limited to 50% of the pad width
  • Calculators:
    • All Through-hole Radial Rectangular component families – missing Assembly Outline
    • Updated the Solder Mask corner radius for thermal pads that have a non-solder mask defined pad
    • Drafting Shape for Round – Unchecking the filled box did not work
This page was generated in 0.267 seconds.
