  New Posts New Posts RSS Feed - OrCAD Editor: Incorrect Version Being Brought Up
simpsond View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote simpsond Quote  Post ReplyReply Direct Link To This Post Topic: OrCAD Editor: Incorrect Version Being Brought Up
    Posted: 01 Aug 2022 at 1:33pm
For OrCAD Editor: when running the .bat file to create a new PCB footprint, the incorrect OrCAD Editor version is being brought up and hangs (need to have 17.2 come up; 17.4 is coming up instead. I have both installed on PC). I have been only using 17.2 in the past and everything has worked well! I recently added 17.4.
In the troubleshooting using the helpful "Allegro-OrCAD PCB Import Instructions.PDF" suggestions, it is mentioned :
"2. Are There Multiple Versions of Allegro Installed?
a. Is the PATH pointing to the correct version?"
Where can I check this 'path' info? I looked over my PC's "environmental variable" settings but could not find a PCB Editor path setting?
Danny
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2022 at 1:51pm
Here is a link to the Cadence tools import instructions -
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2022 at 2:32pm
Look on the last three pages of the PDF Tom posted.
That's where the path variable instructions are. You'll need to restart your computer afterward.
