  New Posts New Posts RSS Feed - Pin1 Cathode
Pin1 Cathode
ArtGon007 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ArtGon007 Quote  Post ReplyReply Direct Link To This Post Topic: Pin1 Cathode
    Posted: 26 Jul 2022 at 10:31am
Is there a specification that specifies pin 1 is cathode for diodes? Or is it just industry standard?Diode issues strike again...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2022 at 12:49pm
Pin 1 for Cathode was started back in the 1990's with OrCAD Layout (which was taken offline in 2007 after Cadence bought it).
I created the CADPRO library and sold a copy to OrCAD as their default library before Cadence acquisitioned them.
All the diodes had pin 1 as the Cathode so OrCAD Capture symbols put pin 1 on the Cathode.
It is a DeFacto standard because OrCAD Capture was the number one most used schematic tool for many years.
We now use C and A for the pin assignments to avoid mistakes and confusion.
This page was generated in 0.285 seconds.
