  New Posts New Posts RSS Feed - Footprint Expert 2022.10 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Footprint Expert 2022.10 Released!!
    Posted: 24 Jul 2022 at 5:36pm
2022.10 was just released!!
Updates & Bugs Fixed:
    • Library sort didn’t work right after renaming column
  • CAD Interfaces:
    • KiCad: crashes building PADS-to-CAD parts
  • 3D STEP Output:
    • STEP file was not saving to selected output directory in some cases for most CAD tools
  • Options:
    • Terminals > Surface Mount > Inward L Flat Ribbon – had duplicate terminal option
    • Components > Through-hole > Mounting Holes had an unnecessary dropdown for Origin
    • Turning off Drafting > Courtyard > Add Outline to Footprint did not work as intended
    • Components > Surface Mount > SODFL/SOFL pin 1, 2 and more than 2 pins added
    • Creating a Thermal Pad with a paste mask pattern, the Pad Stack Manger threw Exception errors when changing the Shape
  • Calculators:
    • QFN – the silkscreen outline was not adhering to the Clearance Option
    • LCC – The pad length calculations need to be adjusted
    • QFN with Thermal – Rotating the footprint so Pin 1 is Upper Left but the thermal chamfer was in Lower Left
    • Removed the “SMD Pad Stack Rules” panel from all Through-hole calculators
