  New Posts New Posts RSS Feed - Length of Termination on Ceramic Capacitors
jnbrown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jnbrown Quote  Post ReplyReply Direct Link To This Post Topic: Length of Termination on Ceramic Capacitors
    Posted: 17 Jun 2022 at 2:10pm
In Footprint Expert dimension L for the length of the termination has a min and max dimension.
Some manufacture's only give a minimum dimension.
For example AVX is 0.3 minimum and TDK is 0.2 minimum.
I am not sure what to use for maximum in these cases.
I am thinking using 0.5 for a nominal value might make sense.
So for 0.3 min I would use 0.7 for max.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2022 at 8:39am
I hate when the component manufacturer only provides a "Minimum" dimension.
What many people do is figure out the min/max average for every package size.
0201, 0402, 0603, 0805, 1206, etc.
