  New Posts New Posts RSS Feed - Mils Instead of mm For Pad Stack Names?
NJ_Ecad_Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NJ_Ecad_Guy Quote  Post ReplyReply Direct Link To This Post Topic: Mils Instead of mm For Pad Stack Names?
    Posted: 28 Apr 2022 at 9:48am
I currently have a library of pad stacks named in mils rather than millimeters.
For example a surface mount rectangular pad 24 mils X by 36 mils Y is called SM24R36. A plated thru circular finished hole of 20 mils diameter with pad diameter of 44 mils is called PTH44C20.
Can I customize PCB Footprint Expert to output pad stacks in mils rather than mm? And is there any control over how it constructs or allows customization of pad stack names?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2022 at 9:53am
In the "Tools > Options > Console > Create Pad Stack Name in > Mils
You can also have the Footprint Name in Mils.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NJ_Ecad_Guy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2022 at 10:03am
That's great news. Thanks.
Where I work we use the metric IPC names when possible but padstacks have always been in mils. I see this tool also supports custom names like manufacturer_partno_#pins such as samtec connectors or for a specific manufacturer non-jedec footprint name.
We are currently using version 10.3 of the LP Calculator by the way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2022 at 10:06am
The LP Calculator 10.3 hasn't been touched since 2010 (12 years ago).
Our latest footprint calculator is called V2022.06 Footprint Expert.
