  New Posts New Posts RSS Feed - Clipped leads for DPAKs
laltmann View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote laltmann Quote  Post ReplyReply Direct Link To This Post Topic: Clipped leads for DPAKs
    Posted: 13 Apr 2022 at 10:37am
I would like to request a feature be added to the DPAK generator.  Many DPAK and D2PAK packages are specified with clipped leads, such as TO-252AA, which specifies that "lead number 2 was removed" and the active terminals are 1, 3 and 4.  Currently this is not directly supported within Footprint Expert.
For simple configurations, like the 3-terminal TO-252AA, the workaround is to specify double the pin pitch and manually rename the pads after generation.  But this does not work for e.g. TO-252BB, which has five leads on the edge with only one clipped.  The 3D model would still be generated with all leads shown as it is now.
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2022 at 11:47am
I think the latest V2022.06 already has this feature.
If you need a webcast demo, let us know and we'll demonstrate "Hide & Delete Pins" and "Reorder Pin Names".
Use the Right Mouse Button.
Post Options Post Options   Thanks (0) Thanks(0)   Quote laltmann Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2022 at 12:56pm
Thanks Tom, I'll give that a try this afternoon.  Can the tool still generate 3D STEP models for packages with hidden/deleted pins?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2022 at 12:58pm
Yes
